Quick need info
Username: Dj_007
Carlisle, KY US
Post Number: 27
ok guys im upgrading my PC... and im buying thie MOBO http://www.newegg.com/Product/Produ...N82E16813136168 ok and i recently as in like in the past year bough ta 700watt PSU but the CPU power connector on it is only 6 pin.. this board has an 8 pin on it.. will my PSU work wiht this board??
Username: Nd4spd18
Post Number: 138
link doesn't work
Username: Motomattic3
California United states
Post Number: 354
ya the link don't work please tell the model number of both the power supply and the board or another link. but as far as I know they won't work togather.
Username: Appzalien
Cleveland, Ohio US of A
Post Number: 120
Look here near the bottom of the page, see the adapter that connects to two regular four pin molex connectors and then creates the 8 pin you need? This can be a pain because it uses up two of your regular power connectors and you should also make sure each is connected to a different 12v line for saftey.
http://www.playtool.com/pages/psuconnectors/connectors.html
Incidentally for the other guys, just because the link didn't work doesn't mean the part number would not run in a Newegg search.
http://www.newegg.com/Product/Product.asp?Item=N82E16813136168
DFI Infinity 975X Socket T (LGA 775) Intel 975X ATX : if you look at the photos you will see the 8 pin EPS.
