Can u get sound with PS2 connected 2 monitor?
Username: Kwd1990
Hi, i have a dell ultrasharp 20 inch monitor with s-video composite and d-sub jacks, and i hooked up my playstaion 2 via composite jack (yellow)
to my monitor since it is compatible and was wondering is it possible to also get sound?
Username: Kwd1990
The reason i connected it to monitor was becasue my tower doesnt have composite, but i; kno it works the same.
Username: Project6
Post Number: 4603
If your monitor accepts audio inputs then you should be able to get sound. Hook up the audio output of your PS2 and you should be in business.
Username: Kwd1990
monitors only have the yellow video pluggin, thats all they come with they dont have the red and white audio ones is their an alternate way or can i buy a splitter or somin, or use the other jacks i have to make it work?
Username: Matt_chew6
do you have any kind of home theatre receiver? I am doing the same thing you are. I have my PS2 hooked up through S video on my monitor and the only way to get sound is by having a A/V receiver.
If you do have computer speakers that have a line in jack, you could get cord that has the RCA female ends to a 1/8' male end. Give it a shot.
Need to Register?
Forgot Password?
Enable HTML code in message
