Tv to Computer
Username: Ep5
Hi people, i'm new and so here goes:
I am trying to hook up my camcorder up to my computer using anlog AV cables so I can eaisly make homemade DVD's.
I have a really tight budget (under $100) so I need somthing cheap that works!! If you need more info, juest say so.
Thanks!!
Username: Zagros
Post Number: 36
I think if you buy a firewire card and an appropriate cable your life will be much easier. They are also cheap maybe under $20 each.
Username: Zagros
Post Number: 37
Username: Project6
Post Number: 8541
Those are digital interfaces, if your camcorder does not have a DVI output it won't work. If you are using analog cables, you need a video capture card.
Username: Fuctupfido
i have a ati radeon 9500 series video card i would like to hook up my TV to This So That I may watch videos from my computer or even just chill back on the couch
Username: Project6
Post Number: 8756
What kind of inputs do you have on your TV?
both coaxial and a/v also if i hook up vcr ive got more a/v
