Samsung and LG Notebook?
Username: Hamjones2
Post Number: 11
What do you guys think of these Notebooks? What are the graphics cards like? and they both burn DVD's right?
Samsung R45
Model Code
NP-R45
Base System
Operating System
O/S
Microsoft Windows XP Professional SP2
Processor
Processor
Intel Pentium M Processor 740
CPU Clock
1.73 GHz
FSB
533MHz
L2 Cache
2MB
Main Chipset
Main Chipset
ATI RC410M
System Memory
System Memory
512MB
Memory Type
PC2-4200 (DDR II 533MHz) DDR2 SODIMM
Memory Banks
2 slot SODIMM's
LCD
LCD
15" XGA High brightness & Non-Glare
Graphic
Graphic Chipset
ATI Radeon Express 200M
Graphic Memory
UMA Max 128MB
Multimedia
Sound
Sound
High Definition Audio, Noise Reduction S/W
Speaker
2 stereo speaker (2W x 2ea)
Sound Ports
Microphone, Headphone
TV/DMB
Type
Ports
S-VHS
Application
Storage
HDD
80GB
ODD
Super Multi DVD RW
FDD
none
Additional Storage
Network & Connectivity
Ethernet LAN
10/100 Ethernet LAN
Wireless LAN
802.11b/g
Bluetooth
Optional
I/O Ports
I/O Ports (System side)
PCMCIA Card (Type I/II), PCI-Express Card, 4EA USB 2.0
VGA, S-VHS, LAN, Modem, DC-in
Input Devices
Keyboard
88key or 89Key Full size keyboard
Touchpad
Touchpad (Scroll Scope)
Other Input Device
Extension
Docking/Port Replicator
Ports
Other feature
Special Features
Software
CD Title
CD Title
OS CD, System S/W CD, Cyberlink DVD Solution (Depend on model)
Installed S/W
Installed S/W
Norton AntiVirus, Adobe Reader, AV Station Premium / Viewer, Samsung Battery Manager, Samsung Network Manager, Easybox, Samsung Update Plus, Magic Keyboard, Magic Doctor, CDS
Security
Recovery
Recovery
Firstware Pro
Security
Security
BIOS Boot up password
Virus
Virus
Norton AntiVirus
Warranty
Warranty
Warranty
1 year
Power
Battery
Battery
Li-Ion Smart Battery (Battery Gauge)
Battery Capacity
6 Cell (4,000mAh), 9 Cell (7,800mAh) - (User Option)
AC Adpater
AC Adapter
Input: 100-240V
Output: 19V / 3.16A (60W)
Adapter output Power
60 W
Adapter Line Fequency
50 / 60 Hz
Physical Specifications
Dimensions (W x H x D )
System Dimensions
329.8 x 272 x 30.7 ~ 35.9mm
Packing Dimensions
Weight
System Weight
2.7kg
Packing Weight
********OR*******
LG LW60
Specifications: Processor Processor : Intel Pentium M Processor 1.73GHz(740) L2 Cache : 2MB/533MHz Memory Memory : 512MB DDR2(533MHz, up to 2GB), Dual Channel Support Display LCD : 15.4" WXGA Resolution : 1280 x 800 Graphics : ATI Mobility Radeon X600 128MB Of Ram Drive: HDD : 80GB ODD : Super-Multi(DVD+/-RW, DVD-RAM) Dual Layer Communication Wireless : Intel Pro/Wireless 2915ABG(802.11a/b/g), Dual Hexa-band Modem : 56Kbps Modem LAN : 10/100 Mbps Ethernet Input Device Keyboard : Full Size 99Keys(Elastic Reaction) Pointing Device : Touchpad with Scroll Function Plus Wireless USB Mouse Expansion Slot PC Card Slot : ExpressCard/54, PCMCIA Memory Card Slot : 4-in-1(SD, MMC, MS, MS Pro) Battery Standard : 6cell Software All Disk included Operating System : Microsoft Windows XP Professional Edition Office 2003, PowerDVD 6, Nero 6, Plus More. I/O I/O : 4USB(2.0), VGA, S-Video, IEEE1394, MIC, RJ11/45, SPDIF(LIne-in), PIO, IrDA, Headphone Net Dimension : 355 x 264 x 30.5mm Weight Net Weight : 2.8kg Features Sonoma. Intel's 2nd Generation Centrino Mobile Technology The Intel's 2nd generation Centrino Platform with a Dothan CPU equipped with 533MHzFSB and 2MB of L2 cache, as well as Mobile Intel915 Express chipset provides you much faster performance in many ways such as CPU, memory and graphics. The Most Powerful Upgrade! 4 times More Powerful ATI Graphics Power The LW-60 with ATI Mobility Radeon X600 Graphics provides revolutionarily improved graphics performance through 128MB of graphics memory and a PCI Express Interface that provides a 4 times faster graphics performance than that of any existing one. Mobility Radeon X600, the first mobile graphics chip built for new PCI Express notebook computers, brings a new level of graphics performance, digital realism & power management to the mobile user -- whether at home or at work. Enjoy Brilliant High-Quallity Video! The Fine Bright LCD The Fine Bright LCD provides a deeper, more realistic video by truly expressing the bright parts brighter and the dark colors darker. The Fine Bright LCD uses low-reflection processing technology based on the polarization effect, and ART (Anti Reflection Treatment), to minimize screen reflection and improve the visual experience. InstantON Player The LW series comes with an InstantON Player so that users can easily enjoy various multimedia such as DVDs, CDs, MP3s, etc. at any time, anywhere without having to boot up the computer. Remote Controller The LW series comes with a compact remote control that is held in the PC card slot of the computer. It can be used for presentations as well as playing back various media such as a DVDs, CDs, MP3s, etc. Wide and Compact! The New Wide Numeric Keyboard Easy and simple documentation work without needing an external-type numeric keyboard! The LW Express comes with a New Wide Numeric Keyboard including dedicated numeric keys and enables numbers to be input more easily. The efficient use of space by the wide notebook enhances work efficiency as well as comfort. Power DVD 5.1channel for More Impressive Sound The LW comes with Power DVD Player 5.1 channel so that you can enjoy Dolby Surround 5.1 channel sound without needing an additional decoder. Multimedia Card Slot: Enhancing your Digital World Iintegrated 4 in 1 memory card reader (SD, MMC, MS, MS PRO) so that users can easily exchange data with digital devices such as MP3 players, digital cameras, camcorders, etc. Port Replicator A Port Replicator is provided optionally which can be installed in the LS70, LW60, and LW70 Express series. For the user's convenience, a typing angle of 7 degrees has been applied to the port. (Option) Advanced Memory Technology, DDR2 Dual Channel Memory DDR2 memory operating at 533MHz, provides twice the data transmission rate than that of DDR memory, supports the enhanced dual channel function, and provides dramatically enhanced memory performance when this option is installed. Advanced Sound Technlogy New HD (High Definition) Audio Technology HD Audio Technology provides 24bit high quality sound that cannot be provided by conventional notebook computers. In addition, Analog 6 channel output is supported so that users can enjoy surround sound more easily. Realistic Sound Quality through the Woofer The LW Express series uses a woofer speaker to reinforce the mid and bass sounds for more realistic sound. 100% Enjoyable Connection! Dual Hexa Band Antenna The Dual Hexa Band antenna breaks the band down into 6 bands and uses an optimized antenna for each band for wider coverage and enhan ced network connectivity. Perfect HDD Security System The core feature of business success is information and information security! The built-in security mechanism prevents data from the HDD from being read even when it is separated from the notebook computer.
