Logitech Z5300e or Z5500
hey all,
for those with the z5300e or z5500, i would like to know how long are the speaker cables. i want to mount the speakers to my wall near the ceiling on all 4 corners of my room. i want to know so that i can plan out everything and prepare to buy extensions.
my room is 12'x 12'. the ceiling is the average 8'.
Username: Spawn_2_extreme
Ontario Canada
Post Number: 7
I've used both setups before, and I can guarantee that you will need to get extensions, if you go with the z5300, the two front are roughly about 5ft and the two rear are about 7 ft, you'll need to go to the source and get some splitters, and some RCA extensions. The z5500 wiring I believe has changed, When I recieved a z5500 at my store the cables were analog, then a few months later the connection hook ups were bare wire which u had to put into the speaker manually, so which ever one u buy, you will need to extend the wiring.
Username: Seanpenn
Post Number: 13
Stick with teh Z5500 ... they are simply the best 5.1 speakers
Username: Project6
Post Number: 8534
How are they the best?
Username: Gamerdude
Ontario Canada
Post Number: 78
Dam Berny I never looked at ur post count before you really have a lot and go with the promedia form klip 2-wat sattelights adn duel 8 inch sub with less distortion then logitech
Username: Project6
Post Number: 8560
Does the post count matter? I've also been a member of this forum since 2003.
Username: Gamerdude
Ontario Canada
Post Number: 80
no i just saw it adn was like WOW thats kool tho
Username: Appzalien
Cleveland, Ohio US of A
Post Number: 67
Did you guys know you can extend the wired remote with an ordinary serial cable with male and female ends?
Need to Register?
Forgot Password?
Enable HTML code in message
