Screen isn't as bright....
Username: Yamahaboy2123
Post Number: 21
Okay well i have my acer aspire 3000 next to my desktop (ibm something)...the screen on my lap top isn't NEARLY as sharp as this screen....i can't exactly find the adjustments on the laptop screen...anything i can do?
Username: Illuminator
Post Number: 2427
Usually there is a 'Fn' button between the 'Ctrl' and 'Alt' buttons in the bottom left of the keyboard. You hold it and the brightnness increase (or setting) key simultaneously. The brightness key is usually an F key with a tiny sun symbol on it. You'll have to look around the keyboard...
