Graphics Card
Username: Mrbockbagok
Edmonton, Alberta Canada
Hello i just bought a HP pavilon a1224n computer. what kind of graphics card will fit, pci, apg, or a pci-e. and is the geforce fx5200 any good, for the price? Thank You
Username: James_the_god
Doncaster, South Yorkshire England
Post Number: 238
Read the HUGE thread titled 'good video graphics card'.
well ok but that doesn't answer my first question "Hello i just bought a HP pavilon a1224n computer. what kind of graphics card will fit, pci, apg, or a pci-e."
Post Number: 239
Well how am I supposed to know that. I don't know what motherboard you have. Check your motherboard manual-it will tell you in there.
Post Number: 7
Ok thanks, but that would be why i listed my computer, yes i know nothing about computers, just trying to learn
Post Number: 241
Ahh, maybe you can look about google for tutorials about computer components and how they work!
I found that about your computer.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&dlc=en&product=1 140029&docname=c00487776
And that:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00361570
If you look under expansion slots, theres only pci slots, no agp or pci express.
You mentioned the fx 5200. I know a lot of people who have this card and for the price its ok. What do you want the card for specifically?
Post Number: 242
Since your computer is new and pci is your only option an fx5700 is the best card to get. The FX is dated now but it's a bit better than the 5500 and 5200. For games, you can overclock it too if you wanted without too much worry.
http://www.newegg.com/Product/Product.asp?Item=N82E16814139166
Post Number: 16
hey cool thanks for your time and info
Need to Register?
Forgot Password?
Enable HTML code in message
