Like
Nikkor lenses
Username: Claudermilk
Post Number: 354
OK, Berny this is mostly pointed at you. :-)
I'm not as familiar with Nikon's line any more & have been tasked with making some recommendations for my sister. She shoots a D100 & needs something better than the kit lens that came with the old N80. Basically looking for a faster walk-around to take pictures of the 1-year-old (isn't this one of the driving forces behind lens sales?).
So, I'm looking for something equivalent to the Canon 17-55 IS, 17-85, or 24-105 IS. Primes are not an option--I've already floated that idea. Research is just beginning, so several options would be great. I don't immediately see anything between a $200 bottom feeder type & a $1100 premium lens.
Username: Project6
Post Number: 8738
So far, the best walk around lens that is readily available is the 18-70mm AF-S. This one came with the D70 kit and well worth having. If you can find and 18-200 VR, which is really hard to find these days (retailing for about $700), I would highly recommend that she grab it.
Nikkor also has the a 17-55 lens that came with the Nikon D50, but I did not like the way it performed.
Post Number: 355
Thanks.
Username: Project6
Post Number: 8750
No problem!
Can you believe this ben idiot?
Post Number: 356
Gotta love trolls. Some people just don't want to hear the truth; I'm tuning him out.
Username: Rwin
Lehigh valley, Pennsylvania
The nikon 18-70mm is a sweet lens. Extremely sharp. Not as fast as the 17-55mm but far less cash. Not as much crying if you get sand in it.
Had considered buying the 17-55mm and did lot's of research on it. Saw lots of info about inconsistent focus, soft images, from a percentage of the 17-55mm -- so make sure to test the actual 17-55mm lens before you buy, and that it's giving you a $1,700 image at a wide aperture. I still may buy the 17-55mm but will test the snot out of it before handing over any plastic.
Username: Rwin
By the way, are we talking about the same 18-55mm nikon lens? I mean this one
https://www.amazon.com/dp/B01AI8H58I
Looks like the price is coming down
Surprised it's offered on the D50?
Username: Project6
Post Number: 12644
oops, that should be the 18-55
Username: Rwin
The 18-55mm is currently $170. It's my opinion that Nikon has realized that the money is with the masses of consumers. Not surprised you didn't like this lens. Perhaps this lens is another sign of the future for Nikon? Not like the old days. Be careful and do your research when buying any product. Nikon has good stuff. And today they've got 'other' stuff. Just my personal opinion. As with anything, stay informed when considering any product, Nikon or otherwise.
Username: Cried
Erie, PA US
Post Number: 9
I just bought one last christmas, and I love it!
Username: Ukcritic
Also have the 18-70mm which I bought as an upgrade from the standard 18-55mm kit lens. Very pleased with it on the whole but don't forget it's not a Pro lens and will soon succumb when put into low light situations. Unfortunately there's no alternative - you get what you pay for with lenses I'm afraid, but at least if you stick with Nikon you'll be sure to get fair optical quality for your money. Get tempted by the Sigma, Tamron or Tokinas and you'll likely be disappointed as they fail to deliver on promises when pushed to their limits.
Username: Bigwatchhe
Thank you for sharing it !It writes well!
Username: Jim1987
Post Number: 7
I will suggest you that always go for zoom lens instead of Prime lens.Its true that picture quality of Prime lens is always better though you will get focal length variation option in prime lens.
Username: Magfan
Post Number: 2508
Primes are generally faster, too.
Never underestimate the power a couple stops gets you when it comes time to hand hold....and yes, even with stabilized glass, of which I own a pair.
At about 100$ the Canon 50mm 1.8 is a terrific addition to any Canon setup.
I use this at weddings for flash-free, available light shots / candids, as well as anyplace a flash would be too.....obtrusive.
My 20-35 2.8 is a close second especially up close or small groups.
Username: Magfan
Post Number: 3544
My, how things have changed in the last few years since I added to this thread.
BOTH Nikon and Canon now have budding lines in the Mirrorless space. The Nikon 24-70 F4 is a VERY good lens when shooting JPEGs. It might need more help with RAW files, which most
people interested in Kid Photos won't bother with, anyway.
Both Nikon and Canon have 'roadmaps' extended forward 18 to 24 months for lenses to be issued.
But don't sell SONY Short! The FE series, and 'GMaster' glass gets good reviews, though it can be $$$$. Sony is ahead of the game a little but the gap is closing VERY fast, indeed.
Username: Magfan
Post Number: 3568
Jim,
I've been a photographer since I was 10 years old, give or take a year.
I've settled ona the 'Three Lens' solution.
1. Good normal zoom. Depending on if you have a FullFrame or APS-C sensor, the focal length will vary. The idea is to go from wide angle to short telelphoto. For Full Frame? A 24-70 will work fine. And for the REALLY wealthy? You can get it in F2.8 which is a large, heavy and Expensive lens.
2. Short telephoto zoom. Extending from where the first zoom Stops to maybe 4x or 5x (again....depends on sensor size) For my nickel? The 70-200 focal lenght is fine. Perfect for the Zoo, light nature stuff and candids from a distance. Also available as F2.8, but are very heavy and can be $$$.
3. Fast PRIME. Yep. I'd go with any of the short prime lenses. For full frame? 28mm? 35mm? 50mm? 85mm? 100mm? The last can be a double function lens and include MACRO focus capability. This will focus to 6" or 8" and is perfect for Bugs and Flowers.
I have an 85mm f1.8 VERY good when it starts getting dark.
And as it turns out, great strides have been made in low-light performance. This means, at least to me, that I don't generally need an f2.8 zoom. One of the lighter and much less expensive f4.0 lenses works perfectly. In the Nikon line, at least, the f4.0 is optically as good or better than the 2.8 of the same 70-200 spread. Don't believe me? Go to DxO lens tests and read the measured data.
Username: Magfan
Post Number: 3572
Photographers who are 'in the loop' know that both Nikon and Canon have come out with Full-Frame Mirrorless cameras AND new lens mount to go with.
The new lens mounts open up some possibilities for new and perhaps better perforrming lenses.
Nikon is about to ship a new lens for the 'S' mount which is used in the 'Z' cameras. It'll be the very popular 70-200 F2.8 Nikon has made several different versions of this lens over the years, some of which have production runs OVER 250,000 units. That's a LOT of lenses.
I'm waiting for some test results on the new lens. I'm hoping for this to better existing Nikkor glass in this category. I already know the price is going to
be somewhere between OUCH! and No Way!
This lens means that in the new mount, you can get a 3-lens setup spanning 14mm to 200mm and all are fixed @F2.8, the 'standard' in this class of optic.
Primes are being issued FIRST as F1.8 and so far are very good indeed.
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Shop Related Deals
Directory
