Trouble with white blowing out
Username: Shawn_ray
New Orleans , LA US
Hello all. My name is Shawn and I'm a fashion photographer. I've switched from film to digital via the Nikon D70. I love digital, but I am having trouble exposing people wearing white. I shoot all out doors. Any ideas?
Username: Project6
Post Number: 3288
Try stopping down 1/3 - 2/3 stop. Expose for the highlights and then expose again for the lows and set your aperture to the middle with a 1/3 negative exposure compensation.
Username: Shawn_ray
New Orleans , LA US
Thanks, Berny. I'll give it a go.
Username: Project6
Post Number: 3653
How is it working out?
Username: Daniel_canada
Post Number: 76
Please tell me you are not shooting people pics in the sun at noon.
Username: Project6
Post Number: 8266
heheh
Post Number: 82
It happens way too much. It's so sad :-( That or cats pics by the front window!
Username: Project6
Post Number: 8284
Oh well :-)
Username: Jackkessler
Post Number: 21
Also check to see whether you are using spot metering or matrix. Spot will meter for only one part of the picture, and let the rest expose the same as the spot. Matrix will integrate the parts.
Username: Magfan
Post Number: 3559
i KNOW this is way-old, but the fashion photog? Needs to learn to use a grey card for 'substitute metering'.
OR?
Buy an external INCIDENT light meter. Something like a SEKONIC would be fine. You hold meter near what you intend to photograph and take that reading. OR you can use it as a reflected meter, just like the one in your camera.
Cameras VARY in the ability to record any given image. My new camera has much better dynamic range.....from brightest to darkest recordable....than any of my 2 prior digital cameras. Generally? The Nikon Matrix Metering should easily handle white in bright.
Need to Register?
Forgot Password?
Enable HTML code in message
