Handycam dcr-pc106e usb - either audio or vid (not both) ?
Username: Jhondoe
Norwich, UK United Kingdom
HI,
Iv just been given my parents old vid cam (sony HC dcr-pc106e) and iv installed the drivers and software that comes with it but when i try to capture the vid stream with sonys Video capturing tool if I select the audio source as USB audio Device it messes up the vid stream (goes green and torn) but if i select my sound card as the audio input i dont get any audio from the cam stream but the vid is fine !! ?
So i can either choose to capture the video OR the audio but not both
Works on my parents comp fine.
Any suggestions out there ?
Cheers all,
JackDinn.
Username: Ieee488
Post Number: 452
http://support.sony-europe.com/dime/camcorders/sd/dv/dv.aspx?site=odw_en_GB&m=DCR-PC106E
Username: Jhondoe
Found out that the problem was with one of my usb hubs, iv moved the connection to another usb port (on a different hub) and its working.
However, now i cant get the "TIME & DATE STAMP" to transfer with the stream ! iv read up on this and turns out you can't "full stop" , what a load of tosh Sony ! no wonder my parents bought another camcorder and gave this one away.
Username: Ieee488
Post Number: 453
one word - Firewire (aka i.Link)
Username: Jhondoe
hmm, you say firewire but im sure that i read somewhere on this forum that even firewire does not stream the time - date stamp.
Need to Register?
Forgot Password?
Enable HTML code in message
