Recovery of footage from a JVC mini DVD rw which was reconfigured
Username: Hughmc
Hi all, I hope some one can help. I have reconfigured the JVC mini dvd disc in my Sony camcorder in error. It now appears blank, both on the camcorder and my computer. It actually contains my son's first steps - I cannot believe that after 27 mini dvds (he's my second born!) I choose this one to reconfigure in error.
Is there any way that I can retrieve the old footage? Just to add further insult I have recorded a little footage on top so I assume I must have lost the bit under that at least.
Hope this makes sence to someone who can tell how to recover the priceless footage.
Help!!
Hugh
Username: Ieee488
Post Number: 350
I am not familiar with the term 'reconfigure' as it relates to DVD media. Re-format maybe?
Username: Hughmc
You are absolutely right lee488 - I knew 'reconfigure' didn't sound right but I just could not remember the exact message. 'Re-format' is what it was. I think this reflects perfectly my technical knowledge! can you help or point me in the right direction?
Hugh
Username: Ieee488
Post Number: 352
If you indeed re-formatted the disc, you are probably out of luck.
Download the program Isobuster. See if the free features can view the files on that disc.
Need to Register?
Forgot Password?
Enable HTML code in message
