What's a good camcorder for around $300?
Username: Lightclouds
Post Number: 8
I am now looking for a good camcorder around $300, I am not sure what kind of camcorder should I get anyway, I want something reliable and easy for use, if it has big capacity that will fine. I will get it from bestbuy, I have found a 5% - 18% off camcorder coupon:
http://www.dealstudio.com/searchdeals.php?deal_id=93743&ru=282
Please give me some good suggestions, thanks.
Username: Project6
Post Number: 15629
Big capacity camcorder? The capacity is dependent on the recording media you use.
If you want a camcorder with a hard drive, you may want to increase your budget.
Canon and JVC makes good camcorders, pick from those and you will be fine.
Post Number: 9
Thanks for your repose, I will have a look at the Canon and JVC, I have heard about them also.
Username: Project6
Post Number: 15661
No worries :-)
JVC Everio has a hard drive to record movies.
