D70s - Nikon Capture & Photoshop Elements
jlettera
I already have Photoshop Elements. Do I need Nikon Capture to import and work with the RAW images from the D70S?
Username: Project6
Post Number: 3209
No, just get the plug-ins from Adobe (go to their website).
Did you install NikonView?
No. I installed Picture Project instead. I also installed Nikon Capture but did not activate the Trial version. However it seems that Photoshop Elements has picked up the plug-in and is handling the .NEF images already. Thanks for your help.
Brian Deaver
On my D70 I get an error message that I don't know what it means. In flash situations, I get an error "r07". Does anybody know what this means or why? Ideas on how to correct?
Thanks, much.
Brian
Username: Cmsmiami
I am currently using photoshop 7. Can I upgrade to PS CS2 simply by using the upgrade,rather than purchasing the new program.
Username: Project6
Post Number: 4346
Yes you can.
