D70 - blank white LCD display
Username: Bolivia
My LCD display went all white. I cannot see the menu, or any pictures. The camera seems to be working, but I canīt tell if the chip is capturing any images. Help! Dave
Username: Project6
Post Number: 3296
Try a camera reset. Check your manual on how this is done.
Check the battery. Check the memory card.
If that does not work you may need to send it in for repair.
