Issues with cyber-shot DSC-p93
Username: Mpics
Oakville, Ontario Canada
Okay. I purchased this camera less than one year ago. I admit I take alot of photo's close to 1000 + so far. Only problem that i have with it is that when taking pictures in humid or hot environments the camera has this irritating tendency to turn on and off (lens goes out lens comes back in.) I find myself reseting the camera and doing a manual shut off which consist of openning the batter cover at the precise moment the camera lens retracts and closes. Is this a problem with my camera or has anyone else had this problem...
Username: Epicura
Hey Michelle,
I got this camera 5 days back and I am also having the same problems.. did u find out any solution.. i will try your method.. if it doesnt work i will give it back.
Username: Project6
Post Number: 3544
Michelle,
That kind of problem is a warranty issue. If the camera is still under warranty have them fix it. If it is working the way it was designed, it needs to be fixed.
pramodh
Return it. That kind of problem is not acceptable for any camera.
