Concrete stands
lauro
Hi guys.
i would like to ask your opinion regarding speaker stand made of concrete. I understand that concrete is very much dead to resonance. Does it mean that concrete can be a very good speaker stand?
Thanks
Username: Monstercable
Post Number: 10
no , metal or wood is better
Username: Nency
Post Number: 118
A speaker stand should be made of something rigid and have as little contact with the floor as possible. A good stand usually only has 3 feet with spikes and brings the speaker to a hight so when you are sitting the tweeter is at ear level.
Need to Register?
Forgot Password?
Enable HTML code in message
