I am looking for seats
Username: Sal1976
I am looking for actual theatre seats...email me if you have any for sale
Username: Bburns
Post Number: 9
Hey Sal, I just purchased a row of home theater leather seats, and they are GREAT!!.
You should come up with a budget first, if not you will over spend, just to many options. I spent a little over 2k and got pretty decent seats.
Hope this helps, the link is to the site I purchased the seats from, it's an informational site yet they have a good related links to buy from.
All the best!
SB
Username: Monstercable
Post Number: 18
yes Seymore purchases seats very often , he is the best for seat selling , contact the link
WHO ARE THESE ADVERTISERS ANYWAY?
Username: Nency
Post Number: 235
Hello,
If you want purchase theater chair then contact this
1.800.632.7657
4705 95th Street N
St. Petersburg, FL 33708
Username: Project6
Post Number: 16052
It's been 5 years. They should have made a decision by now.
Username: Slevapaul
Ahmedabad, Gujarat INDIA
Post Number: 8
Well there are many brands that offers the best chairs which would be more luxurious for seating. They starts from the minimum range to the maximum range and thus you can choose it according to your budget.
Username: Dsmithbfl
Post Number: 11
There are numerous manufacturers of home theater seating. The type you are looking for would largely depend your preferences, budget and the size of your home theater room. I would recommend to take your time and then choose an appropriate seating arrangement at home. If you rush through then you may not end up with the type of seats you have in mind.
Do keep in mind the color of your room where you wish to set up the seating arrangement. If you do not this thought enough time, then you may spoil the overall look of your room.
Username: Angeljoe
Post Number: 10
Viste to online shopping website you will get what you want.
Need to Register?
Forgot Password?
Enable HTML code in message
