Is a DVI cable a DVI cable...........
Fab 5
Here is the question....
Is it worth the extra money to buy a DVI cable for your player to your tv hookup?
the sammy 841 came with a dvi cable. i am not sure on the quality of the cable, but would it be worth purchasing another cable of one of the better know name brnads? I am not talking about the really expensive over $100 ones that are 2 meters in length, just a good one (like bluejean?) that is reasonably priced.
cheers,
Username: Stevegotjobs
No the cable that came with your DVD player is fine, but if you have that itch to want to get a dual link cable for example you need not pay $100 for Monster, BetterCables, or even AQ. Here is an example for dual links and what the prices are for quality DVI-D cables: http://www.hookupaudiovideo.com/shop3/product/dvi-d.htm . I'm serious the single link you have is the same quality for your application then the rest in that length.
