Composite as Component?
Username: Dark_wolf
Hi, I've bought a projector for my home theater that can display up to 480p. The guy at the shop sold me a 150$ cable that really look like a composite one. (It has the colors red-white-yellow) But the fact is that I need a component cable for my projector.
Can this cable be used as a component cable?
In fact, can we use a composite cable as a component cable? Are they made the same way?
Username: Leew
illegal immigranto , Yokosuka, ... SPESNAZ ZOMB...
Post Number: 715
you can try,
Username: Dark_wolf
I made the test : It works!
But the image seemed to be darker... Is it because the cable I used from my DVD to my receiver is a cheap (composite) one?
Username: Samijubal
Post Number: 3115
Everything you could ever want to know about component cables.
http://www.audioholics.com/techtips/audioprinciples/interconnects/ComponentVideo Cables.php
