I need help with power conditioning for 2 chanel audio
Username: Acigarnut
Hello all: This is my first attempt at an internet discussion group. Be kind! I am looking for advice on the best power conditioner/voltage regulator etc. for a dedicated 2 chanel audio only system. I have an all TUBE system and even a tube CD player. I need something that can reduce some of the "noise" and also be useful on the analog side. I have a need to only condition the LP, CD and tuner (plus amp and pre amp I guess). I want a GOOD one, so paying 500 and up is not a problem, but I want to keep it under 1000 if I can. Finally, I have run a dedicated AC line to the stereo and have a PS audio power outlet. It even has it's own dedicated circuit breaker. Brands looked at on internet are Monster and Furman. Thanks in advance for all your help.
Username: Reddfoxx
Ontario Canada
Take a look at:
APC
http://www.apc.com/products/category.cfm?id=15&lid=15
Belkin
http://www.pureav.com/power/
Panamax
http://www.panamax.com/
Need to Register?
Forgot Password?
Enable HTML code in message
