Speaker cable for Bi-Wiring
kamrans
What would be the good cable for bi-wiring paradigm studio 100 speakers? and where can I buy them.
kamrans
I assume 10 or 12 gauge would be better.
Username: Project6
Post Number: 6328
check out partsexpress.com
They should have the stuff you need.
Username: Konoyaro
San Francisco, CA United States
Post Number: 28
Canare 4S11 is a popular choice. You can see an example here:
http://www.ramelectronics.net/html/speaker-cables.html
Several online companies will build them for you such as Heartland Cable, Bluejeans Cable, etc.
If you want to make your own, you might check online vendors such as westlake:
http://www.westlake-electronic.com
kamrans
Thanks for all the help. I'll go with 11 AVG. partsexpress.com looks good.
Username: Starbucks
Post Number: 10
kamrans, i support konoyaro. I have one pair of Canare bi-wiring, performance rated as excellent :-)
