2 antennas on the roof?
Username: Zeekh
Hi I'm new here. Just had a quick question. I was thinking about putting 2 anteenas on my roof to pick up a more OTA broadcast stations. I will probably use the same mast to mount them. Will using 2 antennas adversely effect my picture quality in anyway? Thanks Tim
Username: Captain
Post Number: 56
testing
1
2
3
Username: Captain
Post Number: 57
Username: Captain
Post Number: 58
test
Username: Captain
Post Number: 59
test1
Username: Captain
Post Number: 60
Username: Jwill
If they are pointing in different directions then you can use 2 sockets on the receiver, or combine them into one lead with a diplexer. All you need is to ensure that they are separated vertically by a distance equal to a minimum of a half a wavelength.
If you are pointing both in the same direction they can be joined together to increase signal with a phasing harness, which requires some maths to get it to work properly. They still need the vertical separation to work properly.
Need to Register?
Forgot Password?
Enable HTML code in message
