Coaxial Cables?
Username: Rburtnett68
Hey guys, I want to hook up my TV to my JVC component system but am not 100% sure about how to do it. On the back of my TV there is a port that is orange and says coaxial. On the back of my JVC deck there is a port that also says coaxial. Do I need 1 single coaxial cable or RCA to run from my TV into the back of my JVC component system or do I have to do something with the colored ports on the front of the TV that is use for PS2 and xbox....? Any help would be appreciated. Heres a link to my JVC system.
http://www.jvc.com/product.jsp?modelId=MODL027448&pathId=13&page=1
anyone?
I assume that you want to listen to the TV through your boombox. If the coax jack on your TV is "coax out" and the jack on your boombox is "coax in", then yes, all you need is an RCA cable with 75 ohm resistance (like a video cable, a coax cable that is marketed as "digital", or some well-made analog audio cables).
