Like
Possible bad Coax Cable
Username: Tase2
Post Number: 7
Sat2 not being recognized
Hi
I turned on D* today and recd message-Searching for Sat2signal. I went through all the troubleshooting scenarios and then called D*. (I have the HD10-250) The CSR had me switch the cables and low and behold Sat2 now worked and message stating searching for Sat1. So obviously it has someting to do with that coax connection. He wanted to set up a service call for $70. So I thought before I did that, I would ask around. He did say it could possibly be the multiswitch also, but I really have no way to get to the roof to check.
Seems to me that this should be something that can be fixed for less than $70. Do you think I just need to change the coax part that screws into the back of the receiver? (Not that I know how to do that).
What do you all think I should do?
Thanks
Mark
Facebook
Shop Related Deals
Directory
