I got a question
Umm are the component cables same as the composite cables? Say if I used a composite cable with video, L audio and R audio as a component video cable would it be the same quality? If not what's the difference?
Username: Johnman
They are identical and interchangable.
There are arguments that coaxial is 75ohms while audio composite may just be 50ohms. 50 ohms is normally OK for sounds but insufficient for picture quality. I haven't read any technical document about this comparison. Has anyone read one?
Username: Avman
Post Number: 8
No they are not the same He is right you need 75ohms to get the right picture qulity, They completly diffrent constructions.
Username: Buckeyeshine
Post Number: 27
Gabriel is absolutely right. Composite video cables are NOT interchangeable w/ Component Video cables.
