Help programing ORION MX 850 UNIV. REMOTE
Username: Javmo200
Michigan
Post Number: 24
HELP
I need to know how to program this remote(ORION MX 850)
--Does anyone has the web link to download some of the components and instruction..
Thanks
Username: Javmo200
Michigan
Post Number: 25
If I have erything power through Monter Power HT5100--Can I power the MP5100 and everything will out turn on? I know is a stupid question setting all this stuff is not as easy (if i want to do it right)..
Jav
tomciara
Go to remotecentral.com and find the URC forum. Read the programming guide downloadable from their website before asking "how do I program this". Once you get started you will be amazed at what a great remote you have!
