Wired Remotes
Username: Downbound
I have a Yamaha RX-V1500 sytems I'm installing. I'm going to use some of it's features for zones 2-3 to do some extra rooms up as well. Using a infared extender in the wall and wiring it up will work just fine for my movie/living room however, for the kitchen, bedroom etc, I really don't want to have a wireless remote. Instead I would like to simply mount a panel on the wall with some basic features including volume, on/off and cd controls. However, it appears that there are only these types of remotes for marine environments. While this would be fun, the amp might be a bit too much for my boat =)_ In any case, does anyone know of any company who makes wall mount wired remotes? The amp has plugs in the back for these but yamaha doesn't sell them =/ wtf?
Username: Downbound
anyone?
G_Trump
Xantech and Niles come to mind as a couple of manufacturers of wall mounted infrared based keypads to control audio systems. Any good audio dealer should be able to help here. Check out www.xantech.com or www.nilesaudio.com
