Can I have interconnects made to spec?
Username: Chris2802
Plymouth, Devon UK
Hi,
I am using a Nad 320BEE and a 521BEE CD deck on Mission M35i speakers. Can anyone recommend a good interconnect for these two? I'm looking to spend £40 tops ($80) per cable. I also need to connect my decks aswell, but the output on the mixer is 2 unbalanced 1/4 inch jacks. Does anyone know where I could have a cable made up? or at least get some fairly decent adapters. Finally, is it worth replacing the interconnects attached to my turntables (Technics 1200's) I've seen it done before, and I'm assuming with much smaller signals than interconnects going through them, that the're even more critical? If so where can i find cables with no connectors fitted to one end?
Many thanks in advance
Chris
G_Trump
Chris
There should be hundreds of companies locally to make those cables for you. Ask around. If not, drop us a line at info@gely.ca. We can ship worldwide.
We usually modify 1200's for dj's who are doing the portable gig thing. If your gear is static (ie not moving around) and you don't need longer cables, leave them alone.
Good luck!
