Need help on speaker cable
Username: Z_phat_z
Hello everyone
I just bought the Onkyo 770 system and would like to use better cable for all the components. I'm new at this so can someone please tell me what brand for speaker cable or what kind of cables I need to buy to replace everything that came with the system. Thank you in advance.
For speaker wire, the spools of 14-guage wire that Home Depot sells should suit your needs.
As for cables (interconnects, not speaker wire), I wouldn't replace the ones that came with your system, unless you have a specific reason to (i.e. the connectors are loose or you have reason to believe there are shielding problems).
Username: Z_phat_z
Thank you Nathan.
