Cable Management???
GrandMaster
Just finished hooking up my home theatre system (Toshiba 52hm94 DLP TV, Panasonic Pro Scan E55 Recorder/DVD player, Yamaha 6.1 RX-V630 reciever, X Box, Boston Acoustic Speakers, with Creative Labs Subwoofer).
I have cables on top of cables on top of cables! They are everywhere!! How are you guys running your cables to not make just a jumbled mess behind your AV furniture? Are you guys using any kind of wraps or anything?? Any help and pics is greatly appreciated...
Ben V
I would suggest maybe some twist ties(which is kinda cheap) or some cable groupers also work.
Username: Project6
Post Number: 2216
I use a cable organizer from Belkin. They are just velcro straps that I also use for taming my computer cables.
Lester
Cable ties. Or something from these guy's.
http://www.cableorganizer.com/
I want to know what component video cables are actually capable of producing. Can they transmit 720p?
Username: Littlericky
Springfield, VA USA
Another partial solution to cable-jungle: Cut your cables to shorter lengths and solder new plugs on one end. It's time-consuming and excruciatingly detailed-oriented (just the job for the typical obsessive-compulsive audiophile). But the result can be very tidy and professional-looking.
I recommend the Cable-Safe Cable Manager available at http://cable-safe.com. It is a complete cable management solution that gets all of your cables up off the floor and out of the way.
Use coupon code easy10 and save 10%.
