Assistance with monster cables
Just purchased a Non High def Toshiba 36 inch TV with a samsung combo DVD/VCR for high def. Can someone give me the SIMPLE version of what plug holes to use the monster cables on. The connection with the coax cable works but the salesman told me I needed the moster cables to improve the quality. If so, where they heck do they go so that I can see this so called improved quality.
Username: Htjunkie
Post Number: 8
Plug Holes?? What are you trying to connect it to? A Reciever? Do you want DTS/DD?? What other equipment do you have?
Fab 5
if you bought a non HD tv, how do you expect to get HD at all? That can't happen.
Username: Project6
Post Number: 100
ahem...i don't think this person is still here. It's been four months since the post.
Username: Htjunkie
Post Number: 9
ahem....good point. Thanks.
