2-way splitter - over the air dtv
Username: Johnboypar
Since we can't get cable and satellite would require major tree cutting we have to rely on over the air DTV, which in our location, gives us a very minimal signal for all 7 stations. We are using an antenna which is mounted on a long pole on the roof. We currently have only one tv hooked up to this antenna. We would like to install a 2-way splitter so we can hook up another tv. Since our reception is so bad will adding the splitter degrade the signal so that we will regret this endeavor?
Username: Plymouth
Post Number: 15555
Welcome to eCoustics johnboy!
Buy a signal booster with 2 outputs like this one:
http://www.antennasdirect.com/store/2_way_UHF_VHF_FM_distributio_amplifier.html
Username: Bennsat
if you need about the lnbf product information, we are the professional lnbf,diseqc switch and multiswitch manufacturer.
http://www.bennsat.com
Need to Register?
Forgot Password?
Enable HTML code in message
