Convert S-Video to HD15pin(VGA)cable for projector?
Username: Ferg00
Is there a diagram to convert S-Video to HD15pin(VGA)cable for a computer to projector? This is a ceiling mounted projector that already has s-video run to the ceiling (projector). I would like to be able to just change the other end to 15pin(vga)to connect to a laptop. The wire is 8-wire Cat5.
Username: Project6
Post Number: 1873
is this what you are shooting for?
http://www.svideo.com/vgatotv.html
Username: Ferg00
No, I was wondering if there is a way to wire one to the other with out having to buy a converter.
No
that converter is your only option.
Oh, your projector should have s-video inputs already unless it was designed for a pc.
