Black and white picture with component cables??
I bought a monster component cable for the xbox. The Gamelink 400 is what it's called. I connected it and the picture is only black and white.
Username: L20109
Post Number: 7
Check your video system. Maybe your xbox uses PAL system and your tv is NTSC, the inverse case also cause the B&W colors. If your tv supports varios systems, select the correct video system.
