Dynamat???
does this stuff really help out with increasing your spl? also does it stop most vibrations that happen in your car? what r some other similar products i could look into?
thanks
help!!!
Username: Insearchofbass
Post Number: 564
http://www.sounddomain.com/memberpage/337124/6
heres a site but there was another thread with even more examples
Post Number: 565
found the other link from previous post
JeremyC
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 84
Posted on Tuesday, September 14, 2004 - 11:52 pm:
https://www.ecoustics.com/electronics/forum/car-audio/69478.html Here is some info for you.
Post Number: 566
heres another that might help also on deadening and various topics
and yes it will help with vibrations and also does increase spl
http://ccs.exl.info/frame_installation.html
does that peel and seal stuff work well anybody try it b4.
thanks
Username: Invain
Michigan United States
Post Number: 143
I would buy eDead. It is very cheap, and is almos the exact same thing as Dynomat. I have about half of my trunk done in eDead, and it worked really really good. My only tip would be is to buy a heat gun. The hotter you get the stuff, the less likely it is to come off after a long time.
Username: Symplestiles
Stockton, CA Usa
Post Number: 157
there should be this stuff called Ice Guard at home depot and its weather dampening material (for roofs i believe) its peel and stick just like dynamat. the hotter you get it the better it stays on. some guy said he used 2 layers of it on his entire trunk for 50$ and had half the roll left. thats the road im thinking about taking
