How Good R Audiobahn's
Username: Nightmare
Post Number: 9
hey ive heard alot Of stories with audiobahn subs and i wanted to know how good or bad they r?thanx
Username: Ne0nblakk
Post Number: 26
Well, all over this board, everyone seems to agree that Audiobahn sucks. Crappy SQ, but I guess they're supposed to be loud. If you just want loud, and now SQ, I suppose they'd be OK. Some people say the Q series is good though.
Username: Ne0nblakk
Post Number: 27
If you just want loud, and no** SQ, I suppose they'd be OK.
Username: Nightmare
Post Number: 10
so spl is for loudness and sq is for clarity?
Username: Squanto
No, No Usa
Post Number: 25
yep.
Username: Symplestiles
Stockton, CA Usa
Post Number: 123
for the price of 1 12" sub from audiobahn you could buy two 12s from a ton of MUCH better companies. even if your just looking for SPL you could find cheaper but better subs. whats your price range and what are you exactly lookin for?
Username: Cbigchrisb
Post Number: 33
with experience with audiobahn, i wouldnt use it for either. reliability is their main problem to me.
Username: Southernrebel
Louisiana USA
Post Number: 136
i've used audiobahn and hook up some audiobahn systems...
yes they do get loud but it take way more power to make them get loud than many other subs i've used. (a 600w audiobahn sub getting 600w RMS may only be as loud as a compVR getting 300w!)
they have NO SQ whatsoever! they sound like a monkey beating on a trash can!....scratch that...the monkey would sound better!
Username: Nightmare
Post Number: 11
i have about 600 to spend on that any opinions would be appreciated thanx
Louisiana USA
Post Number: 137
if you want just some daily driver subs...look at kicker compvrs...they are well within your price range.
also JL w3v2's, adire shivas, and eD's...they are also good....(i would go w/ the shivas ir i where in your shoes...$250 a pair)
ccc
The sound quality subs are pretty good IMO. But like someone said, they require alot of rms to make them sound good. In a smaller box the sound quality is good and in a larger ported box they get pretty loud but lose a ton of sq
