Ok Sub Box Suggestions
Username: Stugots
Post Number: 33
I have 2 12" Alpine Type R and 2ohm DVC..
I was thinking about putting them in a Sealed box now there recommended in a .7 - 1.0 Cubic foot Box.
How would it sound in a 2.00 cubic foot box?? or should i just get 2 single 12" 1.00 Cubic foot Boxes and drill them together?..now if i were to drill holes in the box to pass the wires through will that cause problems with sound if i were to seal the holes with silicone?
Username: Stugots
Post Number: 36
anyone?
Username: Pat_l
Tucson, AZ USA
Post Number: 545
Just get one box. The 2.00 Cu Ft box will sound good. Is some times good to have the box a little bigger.
