RE x.x.x 12"
Username: Jmloughrey
Farmington, CT
Post Number: 299
Looking at RE;s site and found there reccomendations on boxs
there SQL box for an x.x.x 12 is 2.1cuFT tuned to 28hz...anyone know of any dimentions for something like this, i'm sure i'll come up with them later today when i'm bored but right now i dont feel like htinking and want the easy answer.
Also, the subs are dual 2 ohm so i can run them at 4 ohms correct?
hater
you can run at 4ohms or 1ohms, depending on what amp you have and the stability of it, i see alot of people running the x.x.x on the hifonics brutus 1500d at 1ohm and that sub pounds also the jbl 1200.1 is another amp i see alot of RE owners using
Username: Insearchofbass
Post Number: 433
yes you can run it at 4 ohms bridged 14 x 14 x 17.75 would be 2.01 cf your going to have fun with that port looks like bends to me plus youll have to figure out the displacement for the wood of the ports and subwoofer
Post Number: 434
add 1.5 inches to all those demensions to acheive the 2.1 cf not including displacement
Post Number: 435
sorry you wanted 2.10 cf that would be 14 x 14 x 18.75 for 2.12 cf adding 1.5 inches for using .75 mdf for all demensions
Post Number: 436
so 15.5 x 15.5 x 20.25
