Whats wrong
Username: Mu_forever
Post Number: 7
i was trying out a new amp for my subs and at low volume they sounded good then when i turned it up, after about 30 sec the subs just stopped working completely. i looked at the amp and the protect light was not on so what caused this? btw i found out later they were running at the wrong ohms. they run at 2 when bridged but the amp runs at 4.(the guy told me wrong specs about the amp)
Username: Particleman
So. jordan, Ut Us
try trying a new ground connection
Username: Tmf
Vicksburg, MI United State...
Post Number: 7
Did you check the fuses yet?
Post Number: 8
yeah, i checked the ground and fuses and both were fine. i hooked them up back to my old amp and they hit but not near as hard.
Thanks
Username: Soccer
Post Number: 293
How thick is your wiring?
Post Number: 9
im using 8 ga. power and ground wire and 12 ga. speaker wires.
Username: Joe718
Post Number: 91
chances are if the amp is not tunrning on at all no power and now no protect light, the amp is most likely gone
Post Number: 10
Both amps work fine, its just that now my subs dont hit as hard before they suddenly stopped firing.
Username: Soccer
Post Number: 299
You MUST make the amp's impedance match the sub's, or have you done it allready?
Post Number: 11
the subs are hooked up correctly
