Deh-p940 or hu and eq
Username: Sralcharger
what should i do: buy a deh-9400
or
buy a good hu and an eq
what should i do ????
Username: Glasswolf
Post Number: 820
if by EQ, you mean one that mounts in the dash with sliders and all, I avoid those for the most part.
They add coloration to the original source.
If you want an EQ, go with a parametric EQ or a 1/3 octave EQ that mounts with the amps, and set it one with an RTA.
If you want a head unit with EQ and crossover all built into the unit, look at the Alpine CDA-9815
