Thoughts on the Kicker Comp VR124
Username: Beek
Post Number: 15
I am looking to buy two 12" subs. Possibly the Kicker COMP VR124.
What do u guys think. Are they any good, or is there any other 12's you could recommend?
Username: Jessejames
NB, PA USA
Post Number: 113
That's not a bad sub, but as everyone else will tell you... Take a look at CerwinVega V-Maxx's, those are good subs! As well, what is your budget? a single RE x.x.x will perform very well.
Username: Beek
Post Number: 16
Thanks Jesse. The only problem i have is that i actually live in england so i cant really get my hands on many of the brands you guys mention.
I dont really have a budget, but obviously dont want to go spending a fortune! Do u think its worth going for two subs or just stick to the one?
Any more subs you could recommend?
Thanks in advance.
Username: Sancho886
El Cajon, CA US
Post Number: 10
www.bladeice.com is a uk distributor where you can get your hands on a RE x.x.x
