Bronze Member Username: Zagguy540Post Number: 12 Registered: Aug-04 | I am thinking about buying this to help me install my audio equipment. Would this help or is it like a rip off? http://www.install-info.com/index.html Thanks, Brandon |
Silver Member Username: Davids2004Houston, TX USA Post Number: 573 Registered: Jun-04 | If you search enough you can find anything you want for free on the internet.; |
Bronze Member Username: SixstarPost Number: 37 Registered: Aug-04 | Its $30.00 for a book. Don't know if its a ripoff, but it isn't all that hard to install your own system. The guy makes it seem like it is impossible to figure anything out unless you are a pro, or you read his book. I would suggest that you go to: www.crutchfieldadvisor.com and read as much as you can, it will help you learn what you are doing a bit more more. They also have a how-to book section: http://www.crutchfield.com/S-Bjj0IBLSONn/cgi-bin/ProdGroup.asp?c=11&g=880&s=0&cc =01&avf=N&search= here is another site that is very useful: http://www.bcae1.com And the tutorials at http://www.jlaudio.com/tutorials/index.html are helpful, especially the one on setting your gain, and calculating box size. Wiring for speakers can be found at CrutchfieldAdvisor. if you don't understand something from those three sites, then go buy a book from Crutchfield. I doubt this guys book is any better than anyone else, you can probably find some other ones at your local bookstore as well. |
Unregistered guest | I need help i just recently put 2 12"s in my car connected to a 600 wt amp and it worked just fine till recently the subwoofer stopped workin the only thing i've noticed rong with it is that this black cord connected to the power input wasn't connected to anything on the other end.. so if any one knows what could possibly be wrong with the subwoofer or where da black wire goes pls let me know.. thank you |
Silver Member Username: InsearchofbassPost Number: 117 Registered: Jun-04 | when you say power imput i dont know if you mean the red terminal on the box each side or the the power wire on your amplifier if its the box connect it if its with the power wire make sure you pull your inline fuse under the hood after everything is turned off and connect the power wire again. thanks, in search of bass |
