jazz Unregistered guest | Could anyone help me out? I didn't pay attention in maths. What would the measurements be if I wanted to make a rectangular box to this size? Its for a alpine type r, and i dont have much boot space. |
Silver Member Username: InsearchofbassPost Number: 116 Registered: Jun-04 | check this site out then you can taylor make it to the measurements you want also just so you know 1 pound of polyfill stuffed in or one inch of fiberglass insulation on the walls except top is equal to 10% boost in internal volume dont go anymore than 2 lbs or 2 inches. http://www.eatel.net/~amptech/elecdisc/spboxnew2.htm thanks, in search of bass |
