trey Unregistered guest | Is there any where that i can find a sealed box that will match two adire shiva. |
Silver Member Username: Davids2004Houston, TX USA Post Number: 583 Registered: Jun-04 | www.proboxrocks.com |
Bronze Member Username: DavenPost Number: 69 Registered: Jun-04 | I say build your own, it will cost ALLOT less than anything premade and will probly be better. Sealed boxes are so easy to make. |
Silver Member Username: Davids2004Houston, TX USA Post Number: 585 Registered: Jun-04 | yes they are as long as you have the tools and some wood working skills. |
