PU-2294A© CL0401Y0482740
Username: Aina
Madagascar
Hello,
Could someone help me on unlocking this radio please?
Model: PU-2294A©
S/N: CL0401Y0482740
Username: Regrooster
Post Number: 15458
A code can only be calculated if you also have a barcode label with a Serial Number beginning C7000000 * * * *
(not beginning with CL though )
Username: Aina
Madagascar
Are there other options?
Username: Aina
Madagascar
I scanned the barcode and it gives the same number
Username: Le_canard
NorwichUnited Kingdom
Post Number: 967
Irina
Username: Aina
Hi,
If you need the code for this radio
Contact ....
{.. c.r.t.m.auto@gmail.com ..}
Otherwise here -- https://www.code-autoradio.com/produit/clarion/
Or here -- https://www.dndservices.co.uk/citroen-pu-2294a-c.html
