2500 watt amp/2 10 kicker subs
Username: Espi209
Ok so I have 2 10 inch kicker comp subs I'm not sure if how many ohm's they are or if they're dual or single voice coil. I recently switched amps I previously had 1200 watt pioneer amp with my subs bridged. The one I have now is power acoustic 2500 watt mono amp. I am using 1 gage wire for power and ground and I believe 10 gage speaker wire with an in line fuse located in the back by the amp. I started having issues with my battery and someone told me I had a parasitic drain I'm thinking it had something to do with the new amp because it didn't start messing up until I hooked up the other amp. So my question is what is the best way to wire it and would I have to know how many ohms my subs are only because I wanted to avoid having to take them out of the box.
Need to Register?
Forgot Password?
Enable HTML code in message
