Building a Custom Enclosure & Want Some Advice
Username: Rockthehouse
United States
Hi everybody, I'm new here so apologises if this is the wrong place for this:
I'm building a box to stick on my vehicle and my dimensions are such:
My bottom is going to be 12 inches wide, by 24 inches long,
My rear is going to be 8 inches tall by 12 inches wide,
My sides will be sloped, the top being 8 inches tall and sloping down to 6 inches and being 12 inches wide/long.
It will be upward sloped forward firing.
My questions are
1) will I be able to fit 2 10 inch sub woofers in this (if not what do I need to do to achieve that),
2) If yes to the first question, do I need to divide the enclosure down the middle or leave it open on the inside?
3) Any advice on what two decent and affordable subwoofers to go with. I have some in mind but I want to confirm.
Thanks!
Need to Register?
Forgot Password?
Enable HTML code in message
