The search for the perfect sub
Username: Ezlayup
I’m running a Audison bit one, av5.1k amp, and a voce k6 component set in my 2015 Lexus IS 250 and I need to find the right subwoofer for my setup. Thoughts please
Username: Bernymac
Phnom Penh Cambodia
Post Number: 4914
I would look for a Image Dynamics IDMAX12 V.4 D4. You'll need a d4 so you can wire it down to 2ohms to get the most out of your amplifier. Based on all the components in your sound system, this subwoofer would probably suit you best since it seems you want more of a sound quality setup and this subwoofer would compliment it nicely compared to other brands/subwoofers out there.
Need to Register?
Forgot Password?
Enable HTML code in message
