How to wire 4 ohm sub to 8 ohm AMP
Username: Tarekdidi2005yahoocom
HI
Going to put my car subwooer to home subwooeer, The woofer in the box(home subwoofer)is died Paradigm servo 15 v2 8ohm
My car sub is 4ohm DVC
Can i connect it to 8ohm Amp?
Username: Delsole
Post Number: 1836
If you wire the sub in series you will get 8 ohms.
Need to Register?
Forgot Password?
Enable HTML code in message
