15in audiopipe subs to which amp and how..
Username: Dboybass
MI
How should I run my 2 15 inch txxsq1555 audiopipe subwoofers (1000 watt rms) in a ported box to my 2400 watt 2 channel directed comp amp? Are they even compatible to run together? I also have 2250 watt powerbass amp, which amp would be better to run with these speakers? And how should I run the speakers to the amp? I'm not too sure about ohm loads either..
Need to Register?
Forgot Password?
Enable HTML code in message
